sudo ./uuu_imx_android_flash.sh -f imx8mm -u ddr4
Error
This script is validated with uuu 1.3.124 version, it is recommended to align with this version.
./uuu_imx_android_flash.sh: line 490: /tmp/partition-table_1.txt: Permission denied
Same error in root user also.and other doubt is i am using i.MX 8M Mini EVK LPDDR4 .its not only ddr4.
i tried sudo ./uuu_imx_android_flash.sh -f imx8mm -u lpddr4 still same issue
Try with sudo ./uuu_imx_android_flash.bat -f imx8mm -a -e
i am using Ubuntu 20.04 OS . I tried with cmd
sudo ./uuu_imx_android_flash.sh -f imx8mm -a -e
same error
I haven't test it in ubuntu20, can you try to copy the image and test it in windows?
