Flash and test the newly created EXT4 Partition
vinothkumars
Senior Contributor IV
Dear All,
I created the EMMC Partition with ext4 filesystem type and I planning to flash some data (maybe dummy data.ext4) on that.
Will you please guide me to flash and check the newly created partition in Linux ?
I have some doubts,
1. Do I needs to create any mount point to flash the Userdata in Linux ?
2. Is there any other way to check (flash/write and read) newly created EMMC Partition ?
Vinothkumar Sekar
Tags (4)
Bio_TICFSL
Hello Vinothkumars,
Please note that accordingly to eMMC specifications boot partition size is fixed during production.
Its size is defined in EXT_CSD structure of the eMMC.
So please make sure that you does not touch boot partition during updating partitions, also disabling udev cache.
Regards.
vinothkumars
Thank you for the reply @Bio_TICFSL
I doing the same way. I just adding the partition. To test this partition I have to flash some data.
Vinothkumar Sekar
