Feeding RAW images from FPGA to imx6
mikecarlos
For an image processing application I want to use imx6 quad plus module.
The RAW image will be supplied by an FPGA.
I see that CSI-2 interface can be used to supply video. However this requires  license costs for the FPGA IP.
Are there other ways I can feed the RAW images from the FPGA avoiding the costs of specialized IPs? Is camera parallel interface simpler to implement? Are three other ways?
thanks in advance
Bio_TICFSL
Hi Milke,
For parallel camera example one can look at imx6qdl-sabresd.dtsi
