hi,everyone:
I have a i.MX53QSB,the NO. is 700-27104 REV C.Now ,I have a question,when i plug the enternet cable ,the PC does not connect my i.MX53QSB.shall i input the new IP for i.MX53,and anybody knows the IP?
best regards!
Hello!
If I right, QSB use DHCP by default, you can configure it manualy after system boot or change U-Boot configuration.
I agree, you need to have a router to give an IP address to the board. Since by default the QSB it is configure with DCHP mode.
Jaime
