Yes. I installed waylandsink and the result is as below
root@imx6qsabreauto:~# gst-inspect-1.0 waylandsink
Factory Details:
Rank marginal (64)
Long-name wayland video sink
Klass Sink/Video
Description Output to wayland surface
Author Sreerenj Balachandran <sreerenj.balachandran@intel.com>, George Kiagiadakis <george.kiagiadakis@collabora.com>
Plugin Details:
Name waylandsink
Description Wayland Video Sink
Filename /usr/lib/gstreamer-1.0/libgstwaylandsink.so
Version 1.4.5
License LGPL
Source module gst-plugins-bad
Source release date 2014-12-18
Binary package GStreamer Bad Plug-ins source release
Origin URL Unknown package origin
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseSink
+----GstVideoSink
+----GstWaylandSink
Implemented Interfaces:
GstVideoOverlay
GstWaylandVideo
Pad Templates:
SINK template: 'sink'
Availability: Always
Capabilities:
video/x-raw
format: { BGRx, BGRA, RGBx, xBGR, xRGB, RGBA, ABGR, ARGB, RGB, BGR, RGB16, BGR16, YUY2, YVYU, UYVY, AYUV, NV12, NV21, NV16, YUV9, YVU9, Y41B, I420, YV12, Y42B, v308 }
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
Element Flags:
no flags set
Element Implementation:
Has change_state() function: gst_wayland_sink_change_state
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Implementation:
Has chainfunc(): gst_base_sink_chain
Has custom eventfunc(): gst_base_sink_event
Has custom queryfunc(): gst_base_sink_sink_query
Has custom iterintlinkfunc(): gst_pad_iterate_internal_links_default
Pad Template: 'sink'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "waylandsink0"
parent : The parent of the object
Object of type "GstObject"
sync : Sync on the clock
Boolean. Default: true
max-lateness : Maximum number of nanoseconds that a buffer can be late before it is dropped (-1 unlimited)
Integer64. Range: -1 - 9223372036854775807 Default: 20000000
qos : Generate Quality-of-Service events upstream
async : Go asynchronously to PAUSED
ts-offset : Timestamp offset in nanoseconds
Integer64. Range: -9223372036854775808 - 9223372036854775807 Default: 0
enable-last-sample : Enable the last-sample property
last-sample : The last sample received in the sink
flags: readable
Boxed pointer of type "GstSample"
blocksize : Size in bytes to pull per buffer (0 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
render-delay : Additional render delay of the sink in nanoseconds
Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 0
throttle-time : The time to keep between rendered buffers (0 = disabled)
max-bitrate : The maximum bits per second to render (0 = disabled)
show-preroll-frame : Whether to render video frames during preroll
display : Wayland display name to connect to, if not supplied via the GstContext
String. Default: null
