Failed building gst-fsl-plugin
Search instead for
caohaifeng
Hi,All,
I have a problem when I build the fsl gnome release package.I have selected fsl-mm-codec-libs and gstreamer-fsl-plugins.
Error occured when build gst-fsl-plugin. The error information is attached below.
video_surface.c:51:28: error: mxc_ipu_hl_lib.h: No such file or directory
vss_common.c:50:28: error: mxc_ipu_hl_lib.h: No such file or directory
Please read the attachment to get more information.
Any reply will be appreciated.
Haifeng
Original Attachment has been moved to: gst-fsl-plugin.zip
Labels (2)
jimmychan
Have you download the Multimedia codecs package? if no, please download it here:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX53_SW
caohaifeng
Yes, I have download it.
