we are facing issue when trying to run the face recognition on NPU using libvx_delegate.so
the command we used to run the code is "python3 main1.py -i /dev/video3 -d /usr/lib/libvx_delegate.so"
on running the code we got the following error i attach image for your reference
we checked gstreamer it was working good ,the requirement is urgent and we appreciate quick response on this issue
HI @sasikaran!
Thank you for contacting NXP Support!
What BSP version are you using?
What board are you using?
Are you using the pre-compiled image?
Hi @sasikaran!
Try using this example instead of the example that you are using.
This example are working as expected.
Best Regards!
Chavira
