- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hi community,
Our customer have a question about i.MX6UL pin.
Please see Table 95 in IMX6ULCEC Rev.1.
The Out of Reset Condition of many pads are "Input, value=keeper".
Our customer want to know whether external pull-up/pull-down to decide input logic, because thye think i.MX6UL will unexpected work by undifined logic if these pads are floating.
Would you let me know whether should they connect pull-up or pull-down to these pads?
Or external pull-up/pull-down is needed since internal pull-up/pull-down decide the logic?
Satoshi Shimoda
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Satoshi
keeper prevents pad from floating, please look at
Bus-holder - Wikipedia, the free encyclopedia
if guaranteed pad input value is needed, one can use external
pull resistor, for selection overriding resistor value please check
keeper value in Table 24. Single Voltage GPIO DC Parameters i.MX6UL Datasheet
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6ULCEC.pdf
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Satoshi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Igor,
Would you give me your comment whether my understanding is correct or not?
Satoshi Shimoda
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Satoshi
yes this understanding is correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Igor,
Thank you for your reply.
OK, I understood.
I appreciate your great support.
Satoshi Shimoda
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi igor,
According to your reply, I understood external pull-up/down is not mandatory, and it is depend on a system of our customer whether external pull-up/down is needed or not.
Is this correct?
Satoshi Shimoda
