Expanding File System Partition On A microSD
3,606件の閲覧回数
erikraynolds
I need to resize my FS on already existing microSD.
I try to follow : Beagleboard:Expanding File System Partition On A microSD - eLinux.org
but missing "resize2fs". Is there a working (functional) way how to do it without rebuilding Yocto/Linux?
タグ(2)
5 返答(返信)
3,325件の閲覧回数
SergioSolis
I don't know of any other method than using resize2fs. I'm not sure its possible any other way, hopefully someone has had experience that can share...
3,325件の閲覧回数
erikraynolds
understand - but how you get "resize2fs"?
I did Yocto build with local.conf:
IMAGE_INSTALL_append = " e2fsprogs" and no resize2fs....
3,325件の閲覧回数
aravinthkumarja
Senior Contributor II
Hi Erik Raynolds,
We can expand the FS size in Flashing script. Can you attach you flash script.
Aravinth
3,325件の閲覧回数
erikraynolds
what's the flashing script?
3,325件の閲覧回数
aravinthkumarja
In yocto after building how you are flashing the images.
Aravinth
