Even when connected to a PC, the USB is not recognized.
izumi_yoshida
The USB is not recognized. The SoC is iMX8Mini(MIMX8MM6CVTKZAA). Please tell me the cause by referring to the device tree settings below.
&usbotg2 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usbotg2>;
power-active-high;
disable-over-current;
dr_mode = "peripheral";
status = "okay";
phy_type = "utmi";
phys = <&usbphynop2_alt>;
phy-names = "usb";
port {
typea_hs: endpoint {
remote-endpoint = <&typea_con_hs>;
&soc {
usbphynop2_alt: usbphynop@381f0040 {
compatible = "usb-nop-xceiv";
reg = <0x381f0040 0x40>;
#phy-cells = <0>;
status = "okay";
izumi_yoshida
Thank you very much. I used it as a reference and resolved the issue.
JorgeCas
Could you please share the USB schematic connection of your design?
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2138209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEven%20when%20connected%20to%20a%20PC%2C%20the%20USB%20is%20not%20recognized.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20USB%20is%20not%20recognized.%20The%20SoC%20is%20iMX8Mini%EF%BC%88MIMX8MM6CVTKZAA%EF%BC%89.%20Please%20tell%20me%20the%20cause%20by%20referring%20to%20the%20device%20tree%20settings%20below.%3C%2FP%3E%3CP%3E%26amp%3Busbotg2%20%7B%3CBR%20%2F%3Epinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usbotg2%26gt%3B%3B%3CBR%20%2F%3Epower-active-high%3B%3CBR%20%2F%3Edisable-over-current%3B%3C%2FP%3E%3CP%3Edr_mode%20%3D%20%22peripheral%22%3B%3CBR%20%2F%3Estatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3Ephy_type%20%3D%20%22utmi%22%3B%3CBR%20%2F%3Ephys%20%3D%20%26lt%3B%26amp%3Busbphynop2_alt%26gt%3B%3B%3CBR%20%2F%3Ephy-names%20%3D%20%22usb%22%3B%3C%2FP%3E%3CP%3Eport%20%7B%3CBR%20%2F%3Etypea_hs%3A%20endpoint%20%7B%3CBR%20%2F%3Eremote-endpoint%20%3D%20%26lt%3B%26amp%3Btypea_con_hs%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%26amp%3Bsoc%20%7B%3CBR%20%2F%3Eusbphynop2_alt%3A%20usbphynop%40381f0040%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22usb-nop-xceiv%22%3B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x381f0040%200x40%26gt%3B%3B%3CBR%20%2F%3E%23phy-cells%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3Estatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Even%20when%20connected%20to%20a%20PC%2C%20the%20USB%20is%20not%20recognized.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EThank%20you%20very%20much.%20I%20used%20it%20as%20a%20reference%20and%20resolved%20the%20issue.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Even%20when%20connected%20to%20a%20PC%2C%20the%20USB%20is%20not%20recognized.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20share%20the%20USB%20schematic%20connection%20of%20your%20design%3F%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
