Ethernet works, but the lights don't work
yzg
Hi:
kernel version:Linux imx8mpevk 5.15.71
phy:RTL8211FDI-CG
I have a problem, my Ethernet is working properly and can access the network, but the Ethernet indicator is not on
Zhiming_Liu
The light is controlled by PHY chip, you should check RTL8211FDI-CG spec and driver.
Zhiming_Liu
