Ethernet stops when WiFi connected
1,244 次查看
himanshugusain
Hi we have a custom sabresd board in which freescale provided android lollipop
is running ,We have connected sabresd to  another device (running on linux )
through ethernet interface(static IP).
Now when we connect our sabresd board to WiFi network  the ethernet connection(between sabresd and other device )
doesn't works(verified by pinging )
What could be the possible reason
Himanshu
标签 (3)
1,075 次查看
BiyongSUN
Could you please check the routing table to find the default routing interface in that time?
1,076 次查看
BiyongSUN
