Hi, all
As our custom's requirement, the Ethernet protocol as below should be supported.
Ethercat, profinet, Ethernet IP, Modbus TCP.
Can you help to confirm if I.MX8M MINI can support these protocols. If not, please suggest one SOC which can meet the requirement based on I.MX or Layerscape series. TKS
Best regards!
Eric Zhu
Hi Eric,
Here do not recommend you to use our i.MX series products. With the ethernet protocol products you need to consider the Power PC with ARM COAR. You can choose the LS104x series products. Hope this can do help for you.
Have a nice day
Rita
