I have a product based on IMX6DL board, and I'm using as O.S android jellybean. I have a strange behaviour related to ethernet Gigabit connections, after a connnection of this type, my board sundley turns off, and I don't receive any message of kernel panic or segmetation fault. Some advice of how to handle this kind of problem?
Hi Juliano
is it working reliably in uboot or linux . One can check i.MX6DL RGMII timings in
Table 60. RGMII Signal Switching Specifications i.MX6SDL Datasheet RGMII Pad Skew Registers
http://www.nxp.com/docs/en/data-sheet/IMX6SDLCEC.pdf
and if necessary try to adjust ksz9021 RGMII Pad Skew Registers.
