Ethernet KSZ8081RNB PHY is not working on i.mx6ulevk
dhvanil_patel1
Senior Contributor I
Hi All,
I am facing issue of Ethernet is not working on imx6ul evk linux. I am using latest Ethernet phy  KSZ8081RNB (date code 1613SA3T M001613CWB ). This Ethenet phy is working  properly on u-boot level.
One more thing KSZ8081RNB PHY with older date code (1418A2TM13A811M03) is working properly.
Need a help to find out the root cause of this issue.
Dhvanil Patel
Labels (4)
Hi Dhvanil
seems first part has silver wire bonding change acording to documents
http://media.digikey.com/pdf/PCNs/Micrel/PPCN140015.pdf
p.2  http://docs-europe.electrocomponents.com/webdocs/13f4/0900766b813f4f61.pdf
so may be suggested to apply to contacts given in these documents for more details.
dhvanil_patel1
Hi Igor,
Thank you for your prompt help.
Can you please let us know how should I have to change in linux kernel driver to support it
