Error msg related to boot cmd in the saberlite imx6 board:
rajanikiranbr
In saberlite Imx6 board when i am running the boot cmd able to see the following error msg:
MMC Device 2 not found
no mmc device at slot 2
MMC read: dev # 0, block # 2048, count 8192 ... 8192 blocks read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Rita_Wang
Here you also need to check the boot up command lines setting in the u-boot.
Hope this can do help for you
Have a nice day
Dan
gary_bisson
Senior Contributor III
Looks like what's on your SD card is corrupted. Please make sure to properly download and flash one of our images:
http://boundarydevices.com/imx6-builds/
Also, all our latest images require to upgrade to latest U-Boot, make sure you have the right version:
https://boundarydevices.com/u-boot-v2016-03/
Gary
