Error in the "Cadence HDMI transmitter driver" by Sandor Yu <sandor.yu@nxp.com>
RKhairulin
I'm using a board like imx8qm-mek. After a resume  kernel print out the error. I found out the code in the file kernel_imx/drivers/gpu/drm/bridge/cadence/cdns-hdmi-core.c:
/* HDMI FW alive check */
ret = cdns_mhdp_check_alive(mhdp);
if (ret == false) {
dev_err(dev, NO HDMI FW running\n");
return -ENXIO;
What does it  mean? What power system can i use to manage the power supply(SW1,SW2)?
RKhairulin
Why support team not answer me? I'm industrial user.
joanxie
what bsp do you use? and share detailed error message to me, how did you get the error message?
