Error Building Process Stopped in imx8mm
i added GPIO in imx8mm-evk.dts file inside freescale folder
&iomuxc {
pinctrl-0 = <&pinctrl_hog_1>;
pinctrl_hog_1: hoggrp-1 {
fsl,pins = <
MX8MM_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x19
MX8MM_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x41
Wen i run ./imx-make.sh
It stops inbetween i hve attached a screenshot.
You may take this for reference.
&iomuxc { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_hog>; pinctrl_hog: hoggrp { fsl,pins = < IMX8QXP_MCLK_OUT0_ADMA_ACM_MCLK_OUT0 0x0600004c IMX8QXP_COMP_CTL_GPIO_1V8_3V3_GPIORHB_PAD 0x000514a0 >; };
