Entering in U-boot prompt
已解决
跳至解决方案
8,408 次查看
fpasino
I have recently acquired a i.MX 8M Nano EVK board and can't seem to start the U-boot prompt. During booting I press any key (on the keyboard) as instructed here, but the operating system starts anyway.
I have tried both the Android system preinstalled on eMMC and the Linux system installed on SDcard (imx-image-full-imx8mnevk.wic found here).
Attached is the Serial Debug log.
Thank you un advance.
1 解答
8,388 次查看
josephzhou1
Contributor V
hi i saw your boot logs :
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
the delay may be set to 0 second , thats why your have no time to press any key to enter u-boot command lah
solution:
pleaae goto your u-boot command and environment to edit ,
bootdelay = 10
it will delay 10 seconds to let your press any key to enter u-boot .
please try it out and let me know how it is work for u or not
thanks all
Joseph Zhou Jianhui / Senior Embedded Software Engineer, Singapore
在原帖中查看解决方案
4 回复数
8,339 次查看
josephzhou1
Contributor V
8,401 次查看
joanxie
what imx8mn evk board do you have? lpddr4 or ddr4? nxp board or customized board?
"During booting I press any key (on the keyboard) as instructed here, but the operating system starts anyway."
>but refer to you logfile, your kernel doesn't start, so when you press any key, your board stuck as the logfile shows?
8,399 次查看
fpasino
The board is that.
I realised that the log was not complete, sorry, I have uploaded it again. It does not change whether I press the keys or not.
The Linux kernel start correctly.
8,389 次查看
josephzhou1
Contributor V
Fastboot: Normal
Normal Boot
solution:
bootdelay = 10
thanks all
