Enabling SPI Mikrobus Flash from u-boot on imx7 SABRE board
1,209 次查看
sonu_abraham
I am trying to access SPI flash connected to microBus on the imx7 SABRE board.
I am getting the following error when trying to probe flash device from u-boot
=> sf probe
SF: unrecognized JEDEC id bytes: 00, 00, 00
Failed to initialize SPI flash at 0:0
I am using u-boot ver U-Boot 2018.07+fslc+g1e13b91
I would like to know what are the changes required in u-boot to detect the SPI flash ..
Thanks in advance,
Sonu Abraham
标记 (1)
997 次查看
blessy_abraham
Hi Sonu Abraham,
I am facing the same issue, were you able to solve this? Could you please share the solution.
