Enabling QCA9377 Wifi Driver for imx8mm-lpddr4-evk
dongremayur777
Could any one help me to enable QCA9377 Wifi Driver with imx8mm.I tried it searching in kernel menuconfig , didn't found anything .
Sanket_Parekh
Hi @dongremayur777
I hope you are doing well
Please add the below line to your Yocto configuration for the qca9377.
MACHINE_FEATURES += " qca9377"
IMAGE_INSTALL:append += " kernel-module-qca9377"
For more information regarding the same, kindly refer to the below thread.
Thanks & Regards
Sanket Parekh
dongremayur777
Thanks ! for the help it worked.
Sanket_Parekh
Hi @dongremayur777
Glad to know that issue has been resolved.
If you have no further queries, should I mark this thread as closed?
Thanks & Regards,
Sanket Parekh
