Enable openVG for qt4 on imx6sl
AccuJie
I tried to port qt4 with OpenVG support on imx6 solo lite based on following page https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Building-QT-for-i-MX6/ta-p/1111319. However, inside"imx-gpu-viv_6.2.4" recipes, the OpenGL libraries are removed.
So I am unable to compile the eglfs plug-in with qt4. Should I just comment on the rm GL* and libGL*  or I need to find other ways to enable openVG with qt4 on imx6sl?
Thanks for your help.
Bio_TICFSL
Hello AccuJie,
If you want to run qt4 you need the 4.1.15v BSP, since is not available from every new kernel:
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
