Enable ethernet Wake-On-LAN feature on i.MX8 with Android
3,157 次查看
yyc1975
Hi All,
We can enable WoL feature on Yocto linux and wakeup device from suspend.
It fails to wakeup system when change to Android.
Did anyone knows how to enable WoL feature on Android OS?
YY
标记 (4)
5 回复数
3,060 次查看
Rita_Wang
Which android BSP are you using?
3,060 次查看
yyc1975
Hi b45499,
We are using Android P9.0.0_2.3.2 (Linux 4.14 kernel) Android P9.0.0_2.3.4-patch.
SoC: I.MX8MQ and I.MX8MD
YY
3,060 次查看
Rita_Wang
This version is only for i.MX8MN and i.MX8QXP, if you are use the i.MX8M series you can try other version.
3,060 次查看
yyc1975
Hi b45499‌,
We have built our own board with i.MX8MQ and i.MX8MD SoC not EVK.
We use "Android P9.0.0_2.3.2 (Linux 4.14 kernel) Android P9.0.0_2.3.4-patch" as code base of our BSP and added our drivers and modifications.
Is that necessary to use "Correct version BSP" for specific SoC?
For the WOL issue, it should be common issue for any i.MX SoC, isn't it?
YY
3,060 次查看
yyc1975
HI b45499‌,
Do you have any idea about the WOL feature on Android platform?
Thanks!
YY
