Enable bluez utilities in IMX8QXP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hi All,
I am currently working on L5.10 on the imx8qxp MEK board. I want to enable hciattach and hcitool on the imx8qxp. How can we enable the same in L5.10?Kindly help.
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Both tools should be included in BSP (also with 5.10) by default.
Harvey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Harvey021 ,
Thank you for the prompt response. After yocto build and flashing , I am not able to find hciattach,hciconfig and hcitool .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Harvey021 ,
I checked with pre-built images. In the prebuilt images, hciattach, hcitool, and hciconfig are present. However, after executing 'repo init' and 'repo sync' commands (repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-hardknott -m imx-5.10.72-2.2.0_genivi.xml && repo sync), I performed the bitbake compilation and flashed the generated images onto the i.MX8QXP MEK board. Unfortunately, the tools hciattach, hcitool, and hciconfig are not available. I am attaching the folder structure of the 'bld-imx8qxpc0mek/tmp/work/cortexa35-poky-linux/bluez5/5.56-r0/image' below. Kindly go through it and guide me if we need to enable any flags in the Yocto SDK to enable hciattach, hcitool, and hciconfig.
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Which Yocto image target have you built? minimal, or base ...etc. should not include them.
try multimedia or full.
Harvey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Harvey,
We are using imx-image-full command for our compilation.
Some warnings we have observed while we are compiling the imx-image-full or bluez5 which we have attached in this reply (bluez5_compilation_warning.png).
Ranjith Kumar.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Harvey021 ,
While performing 'repo sync,' we encountered an issue with cloning the repository of the meta-ivi layer. Below is the log:
fatal: unable to connect to github.com:
github.com[0: 192.30.255.113]: errno=Connection timed out
meta-ivi:
meta-ivi: sleeping 4.0 seconds before retrying
github.com[0: 192.30.255.112]: errno=Connection timed out
error: Cannot fetch meta-ivi from git://github.com/genivi/meta-ivi
Fetching: 100% (16/16), done in 5m30.794s
Fetching: 0% (0/1) 4:25 | 1 job | 4:25 meta-ivi @ sources/meta-ivi
meta-ivi:
Fetching: 100% (1/1), done in 4m25.551s
fatal: failed to unpack tree object HEAD
error.GitError: Cannot checkout meta-ivi: Cannot initialize work tree for meta-ivi
error: Cannot checkout meta-ivi
Checking out: 100% (16/16), done in 6.921s
error: Unable to fully sync the tree
error: Downloading network changes failed.
error: Checking out local projects failed.
Failing repos:
sources/meta-ivi
Try re-running with "-j1 --fail-fast" to exit at the first error.
Repo command failed due to the following SyncError errors:
GitCommandError: 'fetch --quiet --progress genivi --prune --recurse-submodules=no --tags +refs/heads/:refs/remotes/genivi/ +refs/tags/:refs/tags/' on meta-ivi failed
stdout: fatal: unable to connect to github.com:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What about using imx-5.10.72-2.2.0.xml if just hcitool needed.
Harvey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Harvey021 ,
Sorry .I didn't check with the imx-5.10.72-2.2.0.xml. We require the meta-ivi layer also.Why can't we fetch the meta-ivi layer?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Harvey021 ,
Our main confusion is whether the Bluetooth-related package issues we observed are mainly due to a meta-ivi sync issue.
We have tried with the mentioned imx-5.10.72-2.2.0.xml. We also encountered another fetch issue
WARNING: libdrm-2.4.107.imx-r0 do_fetch: Failed to fetch URL git://github.com/nxp-imx/libdrm-imx.git;protocol=https;nobranch=1;branch=libdrm-imx-2.4.107, attempting MIRRORS if available
ERROR: libdrm-2.4.107.imx-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/3880/bus"; export
ERROR: libdrm-2.4.107.imx-r0 do_fetch: Fetcher failure for URL: 'git://github.com/nxp-imx/libdrm-imx.git;protocol=https;nobranch=1;branch=libdrm-imx-2.4.107'. Unable to fetch URL from any source.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can have a try to manually download from the link libdrm-2.4.107 , and to <path-to-build>/downloads. and then touch a copy of it with format like: <filename>.done, without "<>".
Harvey
