Hi ,
I am working on imx8mq board and trying to enable SAI1 mclk.
Device tree configuration:
pin configuration
pinctrl_sai1: sai1grp {
fsl,pins = <
MX8MQ_IOMUXC_SAI1_MCLK_SAI1_MCLK 0xd6
MX8MQ_IOMUXC_SAI1_TXC_SAI1_TX_BCLK 0xd6
MX8MQ_IOMUXC_SAI1_TXFS_SAI1_TX_SYNC 0xd6
MX8MQ_IOMUXC_SAI1_RXD0_SAI1_RX_DATA0 0xd6
MX8MQ_IOMUXC_SAI1_TXD0_SAI1_TX_DATA0 0xd6
};sound-ssm2518 {
compatible = "simple-audio-card";
status="okay";
simple-audio-card,name = "ssm2518-audio";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&dai_cpu>;
simple-audio-card,frame-master = <&dai_cpu>;
simple-audio-card,widgets =
"DAC", "playback",
"DAC", "DAC";/*
"Line", "Unbalanced Out",
"Line", "Unbalanced In";
simple-audio-card,routing =
"LINEVOUTL", "DAC",
"LINEVOUTL", "DAC";
"Balanced Out", "OUTL",
"Unbalanced Out", "OUTR";*/
dai_cpu: simple-audio-card,cpu {
sound-dai = <&sai1>;
};dai0_codec: simple-audio-card,codec {
sound-dai = <&ssm2518>;
clocks = <&clk IMX8MQ_CLK_SAI1>;
clock-names = "mclk";
};/*simple-audio-card,widgets =
"DACL", "HiFi Playback",
"DACR", "HiFi Playback";
"HiFi Playback", "OUTL",
"HiFi Playback", "OUTL";
};&i2c2 {
clock-frequency = <100000>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2c2>;
status = "okay";ssm2518:ssm2518@34 {
compatible = "adi,ssm2518";
#sound-dai-cells = <0>;
reg = <0x36>;
status = "okay";
&sai1 {
pinctrl-0 = <&pinctrl_sai1>;
/*clock-names = "bus", "mclk1", "mclk2", "mclk3";*/
assigned-clocks = <&clk IMX8MQ_CLK_SAI1>,
<&clk IMX8MQ_CLK_SAI1>;assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>;
assigned-clock-rates = <0>, <12288000>;
fsl,sai-mclk-direction-output;
fsl,sai-synchronous-rx;
status = "okay";
SO, I configure device tree for mclk but got error.
failed to get mclk1 clock
Please help me on this issue.
Solved! Go to Solution.
Hi Saurav
one can look at sai1 example below (seems "clocks", "clock-names" are missed)
in imx8mm
sound-wm8524 {
compatible = "fsl,imx-audio-wm8524";
model = "wm8524-audio";
audio-cpu = <&sai3>;
audio-codec = <&wm8524>;
audio-routing =
"Line Out Jack", "LINEVOUTL",
"Line Out Jack", "LINEVOUTR";
what does the following line represents
Hi Saurav
