We are trying to flash cst signed ahab images to imx8qxp evk. The following are the images in hand
Method used to replace uboot
Can you please confirm regarding this method of emmc flashing?
Hello Joanxie,
I want to flash signed image using uuu on imx8qxp. i used sudo uuu -b emmc_all uboot rootfs.wic(this is unsigned image) command everytime. Can you please tell me which command i should used for signed image. name of signed image is now flashed.signed.bin . should i try with sudo uuu -b emmc_all uboot(AHAB-ENABLE) Flashed.signed.bin(this signed image include SCFW, SEFW,ATF,uboot)
I have already mailed to you, pls refer to it
