Edit uboot file to change gpio value
1,508 次查看
丶1u0
I edited the file (/uboot-imx/board/freescale/imx8mm_evk/imx8mm_evk.c ) and compiled the image.While I was compiling the image ,the error above appeared .What should I do for this?
Thanks.
标记 (3)
1,441 次查看
Juan-Rodarte
To modify a GPIO you need to configure in the uboot.dts and you should undo the changes in the imx8mm_evk.c
Diego
1,494 次查看
丶1u0
help~
