I'd like to if iMX8M Quad support echo cancellation function for video calling.
If it is possible, some audio parts are needed to connect to i.MX8M Quad?
Thank you.
Andy
Solved! Go to Solution.
We have VoiceSeeker that is a multi-microphone voice control audio front-end signal processing solution. VoiceSeeker provides high performance beamforming and multi-channel acoustic echo cancellation (AEC).
This solution is supported on i.MX8MM, i.MX8MP and i.MX RT600.
I suggest you take a look on this fact sheet.
Best regards.
Hi, Jorge
Thanks for your prompt reply.
It helps me a lot.
Andy
Best regards.
