ESPI loop back test in iMX8MM EVK
1,088 次查看
gsbalajikrishnan
I am using iMX8MM EVK for project.
I would like to do hardware ESPI loop back test in iMX8MM board. However, I could be able to build u-boot image and boot successfully.
So, I want to know how to build image to test ESPI loop back and where can i find this test code.
Kindly let me know if some steps are available.
标记 (1)
1,065 次查看
Dhruvit
Hi @gsbalajikrishnan,
I hope you are doing well.
One can use the test code mentioned below for the ECSPI loopback test.
imx-test/test/mxc_spi_test/
/test/mxc_spi_test/readme.txt
Please refer to 11.3.1 Enhanced Configurable Serial Peripheral Interface (ECSPI) in i.MX Linux Reference Manual
Thanks & Regards,
Dhruvit Vasavada
