ERROR: nxp-wlan-sdk-git-r0 do_compile: oe_runmake failed and /bin/sh: 1: scripts/mod/modpost: Permi
2,734 次查看
Gourav
when I am creating image first time for imx8mm board via these command
$source sources/poky/oe-init-build-env
$bitbake phytec-qt5demo-image
it is showing ERROR: nxp-wlan-sdk-git-r0 do_compile: oe_runmake failed , and
/bin/sh: 1: scripts/mod/modpost: Permision denied .
Screenshot from 2023-02-15 08-58-00.pngScreenshot from 2023-02-15 08-58-48.png
2,720 次查看
Zhiming_Liu
Hi @Gourav
The BSP you use is not maintained by NXP. The BSP we release doesn't have such issue.
2,660 次查看
Gourav
hey
after changing ubuntu os version this problem solved
Thanks & Regards ,
Gourav
