ERROR: ParseError at /home/ubuntu/bin/fsl-release-bsp/sources/base/conf/local.conf:30: unparsed line: 'IMAGE_INSTALL_append="gcc g++ binutils libgcc libgcc-dev libstdc++'
4,146 次查看
397028133
3,604 次查看
397028133
Thank you for your reply.This problem has solved.
3,604 次查看
gusarambula
It seems that the parse error is due to a syntax mistake on the configuration file. Please try opening and closing with quotation marks and leaving a space before gcc.
IMAGE_INSTALL_append = " gcc g++ binutils libgcc libgcc-dev libstdc++"
3,605 次查看
397028133
