EPDC Connector was not mounted in MCIMX6DL-SDB
1,544件の閲覧回数
ko-hey
Senior Contributor II
Hi all
I want to confirm about the mounting component for MCIMX6DL-SDB.
My customer want to evaluate a EPDC and bought a MCIMX6DL-SDB.
Actually, they want to buy a MCIMX6DL-SDP for evaluation but the board is in EOL status so they bought the board.
They got the board and found that the connector isn't mounted.
 In this situation, could you answer the following question ?
Q1.
MCIMX6DL-SDB isn't mounted the connector.
Is it normal ?
Q2.
According the SABRESDB_DESIGNFILES/Schematics/SPF-27516_C5.pdf, it seems work.
Does it work the EPDC if they get the connector and mount it to J508 ?
Ko-hey
ラベル(3)
3 返答(返信)
1,393件の閲覧回数
joanxie
mx6dl supports eink, could you tell me what bsp version do you use? andorid or linux?
1,393件の閲覧回数
ko-hey
Hi joanxie
I know mx6dl supports eink and I'm not talking about the bsp.
What I want to know is whether the EPDC connector is mounted to MCIMX6DL-SDB or not.
ko-hey
1,393件の閲覧回数
joanxie
yes, I know mx6dl-sdp can support, but I don't have mx6dl-sdb board to test, it should be same, pls check if your edpc is match the board on hardware.
