EMC report for MMPF0100F0ANES-PMIC
已解决
跳至解决方案
1,688 次查看
muthurajm
Dear All,
In Our design we had used MMPF0100F0ANES-PMIC for Powering I.MX6 Dual lite Procesor.
if available can Anyone share EMC report for this PMIC.
Thanks in Advance.
Muthuraj M
标签 (1)
1 解答
1,580 次查看
Hi Muthuraj
I can send you Electromagnetic Compatibility Test Report for the MCIMX6DL‐SD board
which has PMIC on board, please create service request.
在原帖中查看解决方案
3 回复数
1,581 次查看
Hi Muthuraj
1,580 次查看
muthurajm
Dear Igor,
Thanks for the response.
Service request has been raised fro EMC report -Service Request SR 1-4125154982
Regarding that Dual 18 BIT RGB display. It would be helpful if you share any reference document/Design for that.
Muthuraj M
1,580 次查看
muthurajm
Dear IGor,
Thanks for the support,Got the EMC report.
Will check and communicate further if Anything needed.
Regarding that Dual 18 BIT RGB display. It would be helpful if you share any reference document/Design.
Muthuraj M
