Download the images into the MMC on Ubuntu12.04
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
when I Download the images(IMX6Q) into the MMC on Ubuntu12.04,
I used cmd :$ sudo dd if=u-boot.imx of= /dev/sdx bs=1K seek=1; sync
but I can not find /dev/sdx.
I have found mmc\SD card can not be loaded under Ubuntu12.04 system,
But I can use the MFGTOOS in Windows to download the firmware to the board
May I ask what is the reason?How can i solve it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
try lsblk or df to find your /dev/sdx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
you can use sd card reader, insert card to the reader, then use sudo fdisk -l, the pc will list your sd card, sdb or sdc,
then use dd if=
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks a lot! But I used command “sudo fdisk -l” I can not find sdb or sdc!
Please tell me what to do next,
ps:I can download firmware on Windows successfully with MfgTool
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
sdx means sd partition you use, like sdb, for more detailed informatio, you can refer to the chapter 4.3.1 Preparing the card of imx linux user guide.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks Joan, which document about imx linux user guide?please tell me this file name or download links,
thanks a lot!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
pls focus on the chapter 4.3.1 Preparing the card and chapter 4.3.2 Copying the full SD card image
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
thank you very much
