Does miracast function have relationship with LCD resolution
Search instead for
xiaoqianlin
One customer used MX6DL with 480X800 LCD RGB interface(JB4.2.2) and reported  error  when connecting two devices using miracast, I attached the log, can you help to check?
Linda
Linda Lin
Ivan_liu
Hi Linda,
Does the customer use the wifi display sink apk developed by themselves.
The display size doesn't impact the miracast function.
BRs,
Ivan
Ivan_liu
Hi Linda,
BRs,
Ivan
xiaoqianlin
Thanks. Checked with customer, they downloaded the source code and compile it.
Linda Lin
YixingKong
Senior Contributor IV
Ivan.liu, could you hep the customer's issue?
Yixing
