I find the BSPs for i.MX8MM has Linux 5.10.72_2.2.3, does nxp support 5.10.212 or later?
Dear @Eric1994 ,
You can access the link, and you can see all bsp versions we released. suggest you select bsp with kernel 5.15.x or higher. These are newer bsp version.
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/embedded-linux-for...
See below, please!
No bsp based on 5.10.212
Thanks!
weidong
