I use i.MX6DL and RTL8111F(pci ethernet).
When I run iperf in normal status, TX speed is about 600MBits/sec and somtimes disconnection occurs.
But when reducing TX speed to under 300MBits/sec (by adjusting MTU to under 500 or Number of Tx descriptor registers to under 128), there is no disconnetion.
So I want to know whether i.MX6 has a limitation of giga ethernet or not.
If not, advise to me about abobe please.
Solved! Go to Solution.
Hi conan
there is ERR004512 IMX6SDLCE.
i.MX6 has not other limitations of giga ethernet, as you described.
Issues which you are observing, probably related to RTL8111 settings
and local network configuration. You can consult with local network administrator.
chip
Hi conan
chip
