Does i.MX6 older revision chip work well after software is changed for newer revision chip?
satoshishimoda
Senior Contributor I
Hi community,
I have a question about Engineering Bulletin EB803 for i.MX6DQ and EB804 for i.MX6SDL.
According to EB803/804, some software changes are needed to use i.MX6DQ Rev.1.3 or i.MX6SDL Rev.1.2.
Then, does older revision chip (i.MX6DQ Rev.1.2, i.MX6SDL Rev.1.1) work well with changed software?
If the software changes don't affect to older chip's behavior, our customer want to apply the software changes before replace the chip to newer revision.
So could you advice me whether older revision chip can work well when software is changes?
Satoshi Shimoda
Labels (4)
Tags (3)
Hi Satoshi
short answer: yes older revision chip (i.MX6DQ Rev.1.2, i.MX6SDL Rev.1.1)
does work well with changed software.
chip
Hi Satoshi
chip
