I'm interested in use of g_ether and g_mass_storage modules with Linux kernel. Does SDK provide this functions properly working?
Thank You.
Solved! Go to Solution.
They are supported.
I've been trying to get the Gagets to work with my i.mx6 but so far no luck. I've had no trouble loading the serial, mass storage and Ethernet gadget, however my host machine cannot see the device regardless of which gadget I try. I've tried this on both Windows 7 and Ubuntu 12. I've also loaded the appropriate drivers on the Linux machine and still the gadget cannot be seen. From my exiperiece thats all I've need todo on other platforms. Am I missing a step here to get this worrking?
Thanks In Advance
