Does encryption done from user key and black key generated from same user key is going to be same?
1,220 次查看
swapnilpendhare
More description about query.
We can use red key and black key (combination of RNG and user key) for encryption or decryption of data. When we load black key in secure memory of CAAM and tell CAAM that its encrypted while loading.
Then anything encrypted from this key; will it be same as same data encrypted using same user key (from which this black key is derived) ?
As per my understanding to convert user key to black key RNG is involved. and once Decrypted original user key is loaded in secure memory. Hence encryption would be same?
Thanks for your time.
Swapnil Pendhare.
890 次查看
bpe
There is a lot of confusion about red keys, black keys and secure memory in your questions.
Please  study i.MX6 Security Reference Manual Section 5.8.2 and onwards for information
how red keys are converted to black keys and how black/red keys can be loaded and used.
Further discussion of these matters in this Forum is not possible because it requires details
provided in NDA documentation. Should you have  more questions about red/black keys manipulation,
please be sure to open a Support Case. Visit the post at the URL below for instructions how to do that.
How I could create a Service Request?
Platon
