Does enabling Secure Boot in the RT600 family make it unusable in other devices?
1,157 次查看
hxp123
I have a device that is running an RT600 family MCU. I'd like to make a custom development board and I'm curious if I can re-use that RT600 or not.
I believe secureboot is enabled on this RT600, and - as I currently understand it - enabling secure boot sets OTP fuses which will make my custom dev board firmware not be accepted by the MCU.
Is my understanding about this correct? Does enabling secureboot prevent it from being used with any firmware not signed by the original private key?
thank you
1,143 次查看
kerryzhou
Hi @hxp123 ,
   Your understanding is correct.
  If you do the secure boot, then you also need to prepare the related secure app firmware to match it, and download to the flash, then it will be used correctly.
  If just normal app without the related secure configuration, can't be boot any more, as it lack the sign or secured information.
  More details, please refer to the user manual secure chapter, and our tools: SPT and the MCUbootutlity:
1. SPT
https://www.nxp.com/design/software/development-software/mcuxpresso-software-and-tools-/mcuxpresso-s...
2. MCUbootutility
https://github.com/JayHeng/NXP-MCUBootUtility/releases/tag/v5.3.0
the related user manual is:
Wish it helps you!
Kerry
1,139 次查看
hxp123
Hi Kerry, thank you so much for the quick response. I understand.
1,144 次查看
kerryzhou
Hi @hxp123 ,
1. SPT
2. MCUbootutility
Wish it helps you!
Kerry
