Does anyone have bare metal code for the i2c engine on IMX6 single core?
1,630件の閲覧回数
rogergipson
I desperately need some working I2C code for a bare metal application on a IMX6 single core.
I have used the freescale SDK and there is NO working code found in it.
Please help.....
Thank you.
Tecfacet at yahoo dot come
7 返答(返信)
1,166件の閲覧回数
LeonardoSandova
Specialist I
If SDK code is not working, I do not believe there is other place to find code like this.
What is the problem with the SDK I2C code?
Leo
1,166件の閲覧回数
rogergipson
It appears that the i2c code does not want to allow two byte reads to some devices.  I just want to see some code that has been tested to work.
I cannot get a definitive answer from Freescale.  They have been less than helpful.
Roger
1,165件の閲覧回数
YixingKong
Senior Contributor IV
Roger
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
1,165件の閲覧回数
YixingKong
Roger
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel
free to reply with an update to this discussion.
Yixing
1,165件の閲覧回数
LeonardoSandova
Specialist I
If you provide more details on the problem, we can help you more.
1,165件の閲覧回数
rogergipson
I understand that u-boot has this function.  I need bare metal code.
Thank you.
Roger
1,165件の閲覧回数
fabio_estevam
You can use U-boot for this purpose. It has i2c commands you can use for your tests.
