In our design, we are planning to use imx6 solo with 2gb ram but regarding the capacity of RAM supported I couldn't able to find out in TRM. Can SOLO processor support 2GB ram? If it supports what are the procedure I need to follow to make it work?
Manoj
You may use AN4397 (Common Hardware Design for i.MX 6Dual/6Quad and i.MX 6Solo/6DualLite)
regarding differences of devices of i.MX6 series.
http://cache.nxp.com/files/32bit/doc/app_note/AN4397.pdf
In particular, take a look at Table 2 (Summary of feature differences). Memory is supported practically
up to 4GBytes.
Please refer to "i.MX_BSP_Porting_Guide.pdf" of Linux documentation how to configure memory
in U-boot.
https://www.nxp.com/webapp/Download?colCode=L4.9.11_1.0.0_LINUX_DOCS
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
thanks for the support.
