Does Freescale ported Acodec implementation similar to that of OMX player?
2,060 次查看
m_c
Senior Contributor I
This is required as we are using the MediaCodec class, which intern uses ACODEC.
标签 (3)
标记 (3)
1,905 次查看
Hi m.c.
hardware enhanced are only codecs described in attached Extended Codec
Document, sect.6 Freescale Extended Feature Packages Release Notes.
1,906 次查看
Hi m.c.
