Documentation for IMX6SX IOMUX
santu_voonna
I am very much new to IMX6SX programming and would like to know about IOMUX. I believe that there would be a detailed document about IO MUX for beginners. Can you please share the document details?
Thnaks
Rita_Wang
You can refer to the pin mux configuration, using section 4.1.1 (Muxing Options)
of the IMX6SXRM.pdf. And the i.MX_6_Linux_Reference_Manual.pdf the section 3.5 IOMUX
Rita
santu_voonna
I have already gone through this. What I want is the detailed description of IOMUXC. Like the architecture, how mux regs used, how config regs used, how the behavior changes when we change these registers etc. Ideally a document that explain IOMUX in a detailed manner.
