Do I need to pull up PMIC_ON_REQ externally?
Showing results forย
Search instead forย
Did you mean:ย
yan_ding
I have a quick question on the port "PMIC_ON_REQ". According to page 113 of "IMX7ULPCEC", the state is Output/High. So, is this a DC output port to the PMIC? To de-assert this signal, I can pull it down through a switch or IC.
Do I need to pull up this signal externally?
Yan
Tags (2)
Hi Yan
no need to pull up this signal externally.
Hi Yan
yan_ding
Thank you igor.
