Hi All,
I am using IMX6Q based custom board. I am trying to port the Android Kitkat downloaded from free-scale website for sabreSD board. The The hdmi display is not working. I observed the device node for frame buffer is not created. I attached console log and my config file for more details
P.Ashok
Original Attachment has been moved to: IMX6Q_boot_log.txt.zip
Original Attachment has been moved to: config.txt.zip
HDMI interface should not be used with HDMI-to-DVI converter.
Please try using "true" HDMI monitor / TV.
As mentioned in the next thread,
"iMX6Q: HDMI not working"
https://community.freescale.com/message/393635#393635
one may try to adapt the following solution :
http://boundarydevices.com/dvi-support-on-i-mx6-boards/
Yuri
