Disabling LVDS0 after enabling it in the bootloader on IMX8QM
662 次查看
hsaito
We want to disable the LVDS0 enabled in the bootloader before switching to the kernel.
We use iMX8QM and Linux L5.4.47_2.2.0.
We think this can be achieved by setting the register value of CH0_MODE in Pixel Mapper Control Register to 00b midway through.
Is it possible to achieve this?
1 回复
628 次查看
joanxie
if you want to disable lvds in the uboot, you can disable it in the dts file
https://github.com/nxp-imx/uboot-imx/blob/lf_v2022.04/arch/arm/dts/fsl-imx8qm-mek.dts
