Disable ttymxc causes suspending kernel booting
1,316件の閲覧回数
annguyen
Yocto 1.7 is used to build kernel and rootfs as core-image-x11. Kernel boots successfully and results Matchbox-window-manager on display.
However, I'm trying to disable all ttymxc on I.MX6Q board by setting CONFIG_SERIAL_IMX as No ("n"). This makes kernel boot failed, stuck at "Starting kernel ...", only "Yocto project" splash is suspending on the display.
Could you show me if I did wrong? Please advice me more!
Thank you very much!
An.
ラベル(4)
1,195件の閲覧回数
b36401
Please try to set "console=null" in u-boot options instead of disabling ttymxc.
Victor
1,195件の閲覧回数
annguyen
Hello Vitor,
Thank you for your reply!
I tried it but it did not help. So that I am disabling ttymxc.
Could you advice me more?
An.
