Disable CMA on imx6
Disable CMA on imx6
Peter-TS
Hi I found an article describing that in some situations it is beneficial to disable CMA and use coherent pool instead:
How to get rid of CMA
The article has a patch for i.MX8QM do you have a similar patch and steps for imx6?
I need to force gstreamer to use coherent pool instead of CMA on embedded linux.
b36401
You can disable CMA by specifying "CMA=0".
